single phase motor current imbalance and overload
g.mccormick
Jul 2012
IN
961
Single phase 120/208-240V motor.
L1-L2 Voltage = 215
L1 Amp=7.5 (close to nameplate)
L2 Amp=13.7
Motor is tripping overload, motor case is hot to touch.
Any guess as to issue with motor? Could it be the capacitor? If not capacitor, I'm guessing that L2 is partially shorting to ground.
It's time for a new motor. My guess that some of the windings have shorted out to other windings on the L2 side.
L1-L2 Voltage = 215
L2 Amp=13.7
Only a ground fault could explain a current imbalance between L1 and L2 in a single phase motor. Otherwise, you'd be violating Ohm's Law, and that could land you in a heap of trouble. ;)
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
541
Hi PLCs.net! I'm working on a multi-motor system, most motors are single phase, driven by servo drives. I wanted to check what kind of motor...
1,536
Any panel I've built with contactors and overloads has been 3 phase. I'm now quoting on one with some small single-phase loads. Definition of...
24
5,678
Hello everyone, I ran into this 230 single phase two speed motor with two capacitors and a relay (see picture) and have a few questions: The...
1,407
