Single Relay for two Purpose
whussain6
Oct 2013
Newcastle
108
Hi Engineers,
I am using an AB relay(700HA32A2) to power up two devices. Before both were maintained o/p but now one needs Pulse output and other needs Maintained.
I wonder if there is any relay which can do this?
Thanks OsmanMomin,
Actually I need one relay giving both Pulsed and Maintained outputs at the same time from two different sets of terminal.
It will receive Pulsed input and supposed to give pulse output at on terminal and Latch output on other.
On next Pulse input to the relay it will give another pulse to pulsed output terminal, but this time unlatch the other output.
Thanks Osman,
I found that in that PDF but they don't have distributers in UK :( . Anyway I will try to find others atleast now I know there is something like that.
Hello everyone, I ran into this 230 single phase two speed motor with two capacitors and a relay (see picture) and have a few questions: The...
1,422
I find myself needing to protect a large batch (16+) of small single phase 120V motors from overload; I've been told by the client their FLA is...
18
5,610
I attempted to run a single phase motor using a three phase nema 1 contactor and a motor logic ol relay. I wired the load through all three phases...
2,367
234
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
105
