Hello Gents , long time lurker here and many of you have helped me even if you never knew it. Thanks!
I am fairly competent with legacy and logix interfacing but not so much with the msg instruction between processors.
So here's the set-up, a 1769 compact e-net processor on a network with a net-eni module converting the serial from the Slc-04 to e-net. I think all I need is a valid path but the comm tree in the compact doesn't show the SLC on the network?
I set-up a int in the 5000 and did a Slc type read message. But I'm getting hung up on the comm path. Any help is appreciated I'll in the mean time be scouring the KB.:site:
