SLC IO with Compact logix
RTFM, more than usual
I strongly recommend that you read the User Manual for the 1747-AENTR carefully and understand its functionality and limitations before using it in a CompactLogix application.
The 1747-AENTR uses a CIP connection for every module, rather than having a Rack Optimization mode. Even a medium-size I/O application will rapidly use up the available CIP connections of an older 1769-L32E or -L35E CompactLogix model. Modern 5370-series CompactLogix have a different capacity calculation method and are intended for use with the 1747-AENTR.
There are several very good Knowledgebase documents in addition to the User Manual. In particular, I recommend:
1747-AENTR SLC Ethernet Adapter General Information and FAQs
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/471083
SLC to Logix Conversion Basics when using the 1747-AENTR
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/468487
I'm trying to consolidate several slc500's to one 5069 L306er. SLC 500 program sizes are giving in words. And compact Logix controllers are sized...
841
Hello, I have been given the task of upgrading a SLC 500 5/04 cell to a CompactLogix system. I chose to use the L30ER processor. I am keeping...
3,375
Can someone help me understand in detail the differences and limitations between Ethernet IP on a Compact / Controllogix Controller and Ethernet...
2,028
Hello Gents , long time lurker here and many of you have helped me even if you never knew it. Thanks! I am fairly competent with legacy and logix...
3,251
Dear All. My new project for Truck loading System(Oil terminal) with ten Loading Arm. I want to use ten PanelView for ten loading arm( start, stop...
3,572
