SLC 100/150 Cable Pinout
glenncovington
Apr 2002
Gloucester, VA
303
Need some help. I have searched the archives on this topic, but didn't find what I need. I am trying to establish communication with slc 100/150 plcs. Our original RS232 to RS422 converter from AB was made by B&B Electronics. It went from 25 pin female for the PC connection to a 8 Pin Din round connector for the SLC. It also has an external 12 Vdc power supply.
B&B was unable to identify our old cable, but recommended a model 422PP9TB RS 232 to RS422 converter. I now have the converter, but no pinout on the SLC 8 pin Din connector to know how to wire in the cable to the converter. I found a pinout in the archive, but it doesn't match what I have.
Looking a the front of the 8 pin Din connector numbering the pins clockwise from the key point.
Pin 1 Green Wire
Pin 2 Brown Wire
Pin 3
Pin 4 White
Pin 5
Pin 6 Black
Pin 7
Pin 8 Red
Shield
The new converter has connection for:
TD (A)
TD (B)
RD (A)
RD (B)
GND
+12V
If anyone has worked out the connection before please respond
Thanks in advance.
This has come up in the past
Sid - (2 posts) Mar-04-02, 10:00 PM (EST)
2. "RE: SLC 100 Software"
Try this link I found by searching this website.
http://www.isr.uc.pt/~lino/AIR/Arquivo/slc100.zip
You can substitute for the interface a Black Box Corp. Model 800A or B Short Haul Modem.
Pin out for the 8 pin Din connector:
2 = rxd -
1 = rxd +
3 = txd -
8 = txd -
7 = gnd
Remove | Alert Edit | Reply | Reply With Quote | Top
Sid - (2 posts) Mar-05-02, 08:05 AM (EST)
3. "RE: SLC 100 Software"
Update for the Black Box Corp. Model 800 A or B Hookup to a SLC 100/150 Allen Bradley PLC.
Allen Bradley connector Black Box Corp. connection
pin 2 RXD- --------------- TXD+
pin 1 RXD+ --------------- TXD-
pin 3 TXD- --------------- RXD+
pin 8 TXD+ --------------- RXD-
pin 7 GROUND --------------- GROUND
The connections are transposed on the Black Box Corp. end.
The Txd+ goes to the Rxd- on the A-B Side.
The Txd- goes to the Rxd+ on the A-B side.
The Rxd- goes to the Txd+ on the A-B side.
The Rxd+ goes to the Txd- on the A-B side.
This is the info that I also found in the archive. The problem is that I have no wire attached to pin 3 or pin 7 on my existing cable so this pinout provided does me no good.
If I could identify the transmit and recieve pairs then I think I could get things communicating.
Answer Found
Something answering my own question.
I think the archive is right on the pinout, the problem is figuring out how the pins are numbered on the 8 Pin DIN plug. This is what I came up with that is working for me. Thought it might be of use to someone else someday.
Thanks for the responses!
OK Time to jump in the way back machine. Dusted off my old Dell with a serial port and dug out the PIC. Got the ICOM Logistics software up and...
1,707
I need to make some timer chnages to a slc 100 / 150 plc and we have the software and cable but the program that's stored on the laptop which I...
1,897
i am trying to get the software to print out the ladder logic for the conveyor system at work as they are planing to update the slc150's to the...
20
7,252
So being tired of turning on the old win98 laptop and running it to run PCIS software, I was able to get it to run on XP and communicate using...
38,557
What cables and programming software do I need to program SLC 100 or 150's.
2,880
