SLC 100 or 150
Do a search on the forum.
References have been provided in past posts on where to get the PCIS software (AB gives it away now) and where you can get third-party communication cables and adaptors as well as how to get the PCIS software manuals and SLC100 manuals.
Be advised, DOS is required. PCIS will run under winXP but it will run afoul of the OS when it tries to access the serial port.
just a matter of time ...
unasked for advice: rewrite the existing programs and convert them into something like a MicroLogix platform - and get rid of those "oldie-but-goodies" before one goes belly-up and leaves you scrambling for a solution ...
It will run under Win95...
I know where you can get a cable :) I also have the software, if they give it away then I will make you a copy but I need to make sure that its free and they are giving it away
I have Win98 loaded on my vmware but not 95 (yet) I have a laptop that runs 95
Yep... here's a post from Ron (rsdoran) with the links http://www.plctalk.net/qanda/showpost.php?p=199773&postcount=9
OK Time to jump in the way back machine. Dusted off my old Dell with a serial port and dug out the PIC. Got the ICOM Logistics software up and...
1,705
I need to make some timer chnages to a slc 100 / 150 plc and we have the software and cable but the program that's stored on the laptop which I...
1,896
i am trying to get the software to print out the ladder logic for the conveyor system at work as they are planing to update the slc150's to the...
20
7,250
So being tired of turning on the old win98 laptop and running it to run PCIS software, I was able to get it to run on XP and communicate using...
38,554
I need to upload a program from an old SLC 150. I found some software from ICOM SLC Logicistics (V2.09). My laptop is running WinXP Pro, and I...
5,362
