SLC 3/03 to AIC+ to Quick Panel Help
zpelis
Dec 2008
Syracuse
Hello all
I need to connect an Allen Bradley SLC 5/03 (1747-L531) to an AIC+ (1761) (now connected from the PLC to port 2 on the AIC+ ) to another AIC+ (they are conected together using port 3) to an Allen Bradley Quick Panel (QPKSTDN0000-A) (quick panel conects to port 1 on the 2nd AIC)
the quick panel recieves no signal from the plc when they are hooked up this way, however the lights telling me that the different ports are transmitting are all blinking (both AIC+'s) except for port 3 on the AIC+ that is directly conected to the quick panel.
however if i hook up the quick panel and the plc to the same AIC+ there is no problem and everything works fine. I need the system to work using the 2 AIC+'s so i'm looking for any advice.
down the road I am going to need to hook up another AIC+ which i will be conecting to a micrologix 1200 and a maple view touch screen so any advice or pointers would be helpful.
I have the following Items connected for DH-485 per the drawing. SLC 5/03 HMI: Automation Direct EA9-T10CL+13Y19B054 1747-AIC #1: connected...
3,050
I saw another thread similar to my issue but I have different equipment and didn't want to jump on that one so here is mine: PanelView 600...
5,016
HARDWARE SLC 5/03, HMI - C1000, AB GSM MODEM - GDW-11 1) How do i connect all the three devices together via NET AIC. 2) Sample ASCII Logic...
3,161
Hello everyone, I'm trying to get this setup online so it can be programmed remotely. Current configuration (works fine) is: Panelview 550...
3,980
Presently have two old orange screen 1000 PV connected together with 1761-AIC's then to a third AIC in cabinet beside the SLC 5/05, now the...
2,523
