Hi guys,
I've got a SLC 5/05 1747-L551 processor here that won't talk to me.
The Fault light is flashing red, the Ethernet light is solid green, and BOOTP has assigned an address of 192.168.0.1 to the PLC.
Inside of RSLinx I have two drivers set up for it, one is AB_ETH-1 driver, which sees address 192.168.0.1 as an unrecognized device, and an AB_ETHIP-1 driver which sees the same thing.
In RS500, I have setup a dummy program at node 1 using the communication path that I created and tried to download to the processor. Each time I try I get a error message of "DiagnosticStatus failed: 0x4".
I've removed the battery and shorted vbb to ground for over a minute prior to attempting to load a dummy program (at least three times).
The processor does have a 1747-M13 memory module on it as well.
Any ideas?
Thanks!
Any ideas?
Thanks!
