Slc 5/05 1747-l552
Christoph
Sep 2003
Indiana
345
I have a system that was upgraded from an AB SLC5/04
to a 5/05 Ser C. Rev A. Opsys is OS501 ser c. Frn 11.
The E-net connection is slow as a snail. When I connect
with my laptop it takes up to 10-15 minutes. Have tried
10 and 100 mbps full duplex settings and even tried the half
duplex settings but can tell no change. Any ideas out there??:mad:
Well, maybe post a screenshot of the configuration screen.
Other than that, remove other variables. How are you connecting to it? Are you using a switch, a hub, or connecting directly to the Ethernet port? Are you plugged into that same switch/hub or are you connecting through a plant network. Have you tried using different ports on the hub/switch or tried using a different hub/switch. If you are using a hub, get rid of it and use a switch!
Is your RSLinx up to date? Version 2.55 is the current version as of now.
When you get online with the controller, what is the scan time?
OG
Don't use half-duplex unless you need it. It will slow things down considerably.
I am looking for all the componets to put in a system using remote I/O. I think I need a 1747-SN scanner module. Do I need one for each remote...
1,450
I upgraded from a PLC 551 to a 552, to go from 16K to 32K memory. Everything works fine except that RSlogix tells me I have reached the memory...
3,482
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,607
I have the following Items connected for DH-485 per the drawing. SLC 5/03 HMI: Automation Direct EA9-T10CL+13Y19B054 1747-AIC #1: connected...
3,047
Hello, First I looked at Manuel and Plctalk but I did not find or maybe not understand. How I can connect ''HTL / Push pull-24 volt encoder'' to...
2,525
