Slc 5/05 1747-l552
berrabbit5849
Nov 2011
Daingerfield,Texas
117
I am looking for all the componets to put in a system using remote I/O. I think I need a 1747-SN scanner module. Do I need one for each remote rack? I think I need a 1747-ASB for each remote rack? Will only be doing remote I/O. Do the scanner and ASB connect via Blue Hose ? I want to connect a PC to the processor at all times for troubleshooting. Does the processor have a ethernet port for this or is it another card.
No, only the rack with the processor.
Yes.
Yes, make sure you have termnation resistors at each end of the network.
See link for the manual below.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1747-um013_-en-p.pdf
Yes. It also has a serial port.
Btr btw
On my remote racks will I have to program a BTR and BTW to communicate with these. Can you show me an example ? It has been a long time since I have done this. Also there was something about a "G" file to fill in.
I have a system that was upgraded from an AB SLC5/04 to a 5/05 Ser C. Rev A. Opsys is OS501 ser c. Frn 11. The E-net connection is slow as a...
1,403
I upgraded from a PLC 551 to a 552, to go from 16K to 32K memory. Everything works fine except that RSlogix tells me I have reached the memory...
3,481
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,605
I have the following Items connected for DH-485 per the drawing. SLC 5/03 HMI: Automation Direct EA9-T10CL+13Y19B054 1747-AIC #1: connected...
3,047
Hello, First I looked at Manuel and Plctalk but I did not find or maybe not understand. How I can connect ''HTL / Push pull-24 volt encoder'' to...
2,524
