SLC 500 1747-L541 contollers
srv
Aug 2010
QATAR
109
I have one SLC-1747 L541 controller.when i tried to communicate with my computer through RS 232 and USB adaptor,an error msg is coming like "check your cable or switch setting" on autoconfiguration .I am using rslinks 2.50 version for linking.Can anybody advice me what setting i have to do in RS links to communicate to PLC using RS 232 Port,How i can use the DH485 port
Also do you know how the SLC's serial port is configured? ( DF1 or DH485)
Do you have its offline file? If so take a look at its channel configuration or post it here and someone will help you look. ( zip it first then post).
The configuration of its port will determine what driver you will have to use in RSLinx to get connected.
Iam using *** RS232-USB adapter.I hopes its good.I am getting connection in RS links ,but showing Slc500 as P02/30 something like that.also "check your cable "in autoconfiguration set up.Is it bcs of the port is configured as DH 485.
Can you post your .RSS file? ( zip it first) Or post a screen shot of the SLC's serial port configuration.
Hello, First I looked at Manuel and Plctalk but I did not find or maybe not understand. How I can connect ''HTL / Push pull-24 volt encoder'' to...
2,526
Dear All, I need to upload program from slc 500 fixed controller (1747-L40C), series "B" and FRN "6"and to download the program to another PLC...
23
7,278
Good Afternoon, I plan on replacing some SLC 500 PLC's with CompactLogix. Could you tell me what the equivalent processor is in the...
2,291
Having a problem with is processor PLC SLC 500 cat:1747-L541, the fault light is flasing and cannot go online and again the DH+ comm. is flushing...
1,794
Good Morning , I have a SLC 500 rack with a 1747-L542 CPU and 2 DeviceNet scanner cards. I am having a terrible time going online with this...
4,365
