Slc 500 eeprom
kongshitt
May 2011
indianapolis
28
Ive got an old school SLC 500 (1747-L30C) and im pretty sure the processor is fried. (It was pulled with an old machine, and when it arrived we can see the slag remnants from the crew taking the machine apart with a "blue wrench")
We are hoping to pull the EEPROM and try to harvest the program from it, so we can transplant it into a new processor.
The EEPROM module is marked 1747-M1
Can anyone help me out with compatible SLC processors? I have a SLC 5/01 and a SLC 5/04 processor I can put into a spare rack and see if we can get it powered up, but I'd rather not fry anything worse than it is already.
Thanks!
The book says they are with the SLC5/01, see pdf's below.
You might want to contact your local AB rep.
To add to my above post, I am not sure what would happen if you tried to load that
old program into a different processor type. My guess is it would not do it. But I have never tried it.
Hello I have a couple of processors a 5/01 and a 5/02 both with eeproms When i try to load program onto either eeprom with either processor a...
4,808
Hi all, yesterday I was at a customer site doing a PM and after making a couple of minor mods to the program, I went to back it up to EEPROM (yes...
2,406
I recently had a 5/04 lose its program for what I'm atributting to a cheap battery that was installed 6 months ago so installed a EEPROM. I...
1,223
1.) ROM/RAM FLASH MEMORY: The SLC500 RAM battery lasts (2) years as I recall. On a non-EEPROM memory - if the battery is not replaced and the PLC...
2,595
Hi, I have an AB SLC 500 with the fixed IO catalog number 1747-L20C, I just purchased this and it does not have the EEPROM chip in it. Does...
3,584
