SLC-500 EEPROM Question
bright676
Nov 2012
va
494
I recently had a 5/04 lose its program for what I'm atributting to a cheap battery that was installed 6 months ago so installed a EEPROM.
I loaded the program to it and set S:10 to a 1 so it will load the EEPROOM on memory loss
Is there any thing else that I have to do to so it will load on memory loss? Will the key have to be turned on a memory loss or will it auotomaticly load it? We keep all of our keys in remote posistion all the time.
Thank you.
It will load regardless of switch position. Curious as to whether you measured the battery voltage to see if it was truly the cause. I have seen memory loss occur with a good battery.
Hello I have a couple of processors a 5/01 and a 5/02 both with eeproms When i try to load program onto either eeprom with either processor a...
4,807
Hi all, yesterday I was at a customer site doing a PM and after making a couple of minor mods to the program, I went to back it up to EEPROM (yes...
2,401
Ive got an old school SLC 500 (1747-L30C) and im pretty sure the processor is fried. (It was pulled with an old machine, and when it arrived we...
3,891
1.) ROM/RAM FLASH MEMORY: The SLC500 RAM battery lasts (2) years as I recall. On a non-EEPROM memory - if the battery is not replaced and the PLC...
2,595
Hi, I have an AB SLC 500 with the fixed IO catalog number 1747-L20C, I just purchased this and it does not have the EEPROM chip in it. Does...
3,579
