SLC 500 Battery expired not EEPROM
Scott180zip
Oct 2008
Brunswick, OH
1.) ROM/RAM FLASH MEMORY: The SLC500 RAM battery lasts (2) years as I recall. On a non-EEPROM memory - if the battery is not replaced and the PLC is powered down, does the processor lose all of its memory?
2.) How can you verify the date a program was written if it was saved with no changes made: meaning the last date changes were made. Is there a tracking log?
3.) Which PLC Manufactures are using Flash Memory?
Thank you.:confused:
Where is the battery located ? Is it on the left side of the cpu hidden by the power supply? Thanks
1,683
Good Morning , How do you replace the battery on a SLC 500 CPU without loosing the program , since you need to remove the CPU , and the...
12,056
Does anyone know if a 3.6V, after market battery will work? Or could this possibly cause issues?? Thanks in advance!
6,677
I am not real familury with old slc 500 this is 1747-l40a Its droped the program cpu light flashing I assume due to a low battery. So my...
4,513
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
971
