slc 500 battery?
joeparrish
Nov 2007
owensboro ky
161
I am not real familury with old slc 500 this is 1747-l40a Its droped the program cpu light flashing I assume due to a low battery.
So my queistion is is where is the battery? I pulled the cover off that is to the left front (it has a fuse inside) I cant find a battery.
Sounds like you're in the right neighborhood... the battery holder is right over the fuse, plug should be just over and to the right.
For the Installation and Operations manual for those old fixed SLC500s, search for publication 1747-6.21 in AB's literature library.
HMMM? If the battery is low the "Low Battery Led" should be on.
See PDF's below for battery location and troubleshooting guide.
Did you have any spikes recently or a bad storm??
If the answer is yes, it wipped out the entire program or part of it.
A reload is due.
I agree with Mickey, if the batetery was low you would have gotten the "Low Batery" indicator.
Where is the battery located ? Is it on the left side of the cpu hidden by the power supply? Thanks
1,686
Good Morning , How do you replace the battery on a SLC 500 CPU without loosing the program , since you need to remove the CPU , and the...
12,059
Does anyone know if a 3.6V, after market battery will work? Or could this possibly cause issues?? Thanks in advance!
6,683
1.) ROM/RAM FLASH MEMORY: The SLC500 RAM battery lasts (2) years as I recall. On a non-EEPROM memory - if the battery is not replaced and the PLC...
2,595
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
976
