SLC 500 Fixed Controller L20 Fault
gusterminator
Feb 2009
Thunder Bay
85
I'm getting a fault as soon as I put the controller in run. When I go to go to error the plc is saying the problem is
Major error halt S:1/13 = 1
Under description
The module in slot 0, which is required for the user program is detected as being the wrong type.
I have no moduals in Slot 0 or slot one.
Thanks for any help solving this.
What's shown in the I/O configuration in the program? If the program expects a module to be there and it isn't (or the wrong type) it will fault the processor.
The fault is a flashing fault. It only comes on when I try and run the program. Here is the RSS file I am trying to use. It has no programming on it I was just trying to start from scratch...but couldn't get the fault to leave.
I will post here from now on...I didn't mean to make a copy :0)
I figured it out thanks for the help. I had two controllers the same. I was pulling the rack configuration from the 1747 L20A and writing it to the 1747L20C. So it was writing the configuration for a AC input instead of a DC Sink input.
Does anyone know of a free program I can use to upload the program from an AB SLC 500 Fixed and read the error code? I don't want to do any work...
1,584
I am needing to connect a fixed style SLC-500 to an ethernet network for data collection to an OPC Server. I see the Fixed Style SLC-500 has an...
2,577
I have a question regarding the SLC 500 Fixed IO. It currently has 1k program memory. If I installed the 1747-M2 4k module will I now have 4k...
1,295
I would like to hook my SLC 500 to my Comunication server or hook it directly to my hub RJ45. Does any body know what product I should buy to...
3,471
I'm getting a fault as soon as I put the controller in run. When I go to go to error the plc is saying the problem is Major error halt S:1/13 =...
2,336
