SLC 505 Outputs not firing
Mark_J
Apr 2024
Tampa, FL
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs will stop firing. The program is still executing normally and the output bits come on in the program but the outputs don't work on all the output cards. The processor is a series C processor with 1746 OB16 output cards. Anyone seen then this before?
I have seen this behavior when one of the outputs (not fused), was connected to a load that was intermittingly shorting to ground. This would "drag" down all the outputs on that card, but did not bother other output cards. Next time it happens, try forcing all outputs off, then energize them one at a time until you find the problem. Or, (safer), next time it happens determinate the output wiring one output at a time.
Hello I have a problem with configuration the Flex I/O profibus module. I have a PLC SLC 505, Profibus scaner on PLC Rack [SST-PFB-SLC] -...
50
Hello, I inherited a control system one of my predecessors thought it was a good idea to put logic for cant optimization and Kinetix motion...
3,661
Probably a silly question and asked a hundred times already, but i tried to do some searching here and couldn't find this question. I have 502's...
3,047
I'm a mega noobie when it comes to PLCs and the such. I'm a network guy. We are currently experiencing an issue where the SLC immediately faults...
1,935
Hi guys I hope your all safe and well , I have a question regarding a slc 505 on ethernet is it possible to add a ethernet remote I/O module...
1,896
