SLC Fault Codes
2-D-MAX
Oct 2008
toronto
Hi All,I have a question for all. when you have a processor and there is a fault,you go to fault and see whats the problem.QUESTION IS WHERE IN THE PROCESSOR CAN YOU GO TO SEE THE FAULT CODES. xx25 ans so on. thanks All.
Using RSLogix, you can open the status file and go to the "errors" tab. It should show the fault along with a description. Also, in the RSLogix help files you can find a list of all of the error codes.
Under Processor Status on the left side of you RSLogix500 software click on this and select the error tab. That will tell you your error and then you can also search the help files for the error code.
Hope this helps.
I assume the xx mean 00 and from the help files...
0025 There are excessive JSRs in the STI subroutine. This non-recoverable error occurs at run time.
RSLogix 500 - Copyright Rockwell Software 2000, 2001, 2002
The major error code can be monitored in ladder and could be displayed on an HMI as well. S:6 will contain the hexadecimal error code when a major fault is declared.
A major error will bring your ladder to a screeching halt...unless you have configured a fault routine.
You can monitor the address directly from an HMI though.
can anyone help with a list of fault codes including Are, noc any help please the above fault codes do not appear in the manual
7,640
Does anyone know where to find the Fault codes for SLC? We recently moved a 150 HP Motor about 20 feet from where it was previously. Nothing has...
11,896
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated. Recent Example: A power supply wasn't screwed in...
423
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,016
Has anyone ever seen this fault or have any insight as to what it was. I found this on an SLC 505 after we had the main breaker off working in...
1,412
