slc 500 fault codes
Gshill01
Mar 2004
can anyone help with a list of fault codes including Are, noc
any help please
the above fault codes do not appear in the manual
look in your other post ... I think I've answered your question there ... also ... it would be a GOOD idea to give us the actual part numbers (example: 1747-ASB) of the hardware you're working with ...
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,016
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,801
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,136
Dear All experts, I have one old PLC Rockwell SLC 500 5/03 and its serial port (RS232) port is not responding on RS232 DF1 driver. I dont have any...
18
4,092
I am getting the following error on my PLC and I haven't experenced this kind before. What should I do? I can't find that error code online. We...
3,109
