bernie_carlton
Gmferg is correct (patting each other's back). The search has no idea what the value of the indirect will be at runtime. It could be anything within the range of the data table. Should it show all possible bits as used?
Check every use of indirects which reference the B3 data table. Start with anything starting with B3:5 for indirect bits. Then B3 with indirect words. You may find something. It may be a long exercise in nothing. Or it may be a lesson in blindly taking the next available suggestion from RSLogix.
