slc pid
hanyrag
Jul 2009
cairo
20
i need to make pid application by slc(5\4)processor,where i need to constant gas pressure at sp.my pv is analog signal (4-20 MA)CORRESPONDIN TO PRESSURE MEASURE, MY CV IS P\I CONVERTER(O%-100%)TO REGULATE THE CONTROL VALVE.IT'S THE FIRST TIME TO DEAL WITH PID,I READ IN SLC INSTRUCTIONSET AND MAKE THE SOFTWARE BUT I HAVE TWO PROBLEM AND NEED TO HELP.
1-WHEN MAKE SIMULATION TO MY PROGRAME BY RSLOGIC EMULATE 500 THE PID NOT RESPONDE
2-HOW MAKE TUNING AND HOW CAN GET TIME RESPONSE SIMULATION WHEN TUNING
welcome to the forum ...
bad news: the EMULATOR will NOT run the PID equation for you ...
suggestion: post your existing .RSS file and let us take a look at it ... make sure that the input and output signals are properly documented ... even if the program is still in its very first stages of development (rough draft) it's still a LOT easier to help you with your questions if we have that file in front of us ...
so ... forget about using the EMULATOR for PID work ... now let's move on from there ...
good luck with your project ...
you'll probably have to ZIP the file first before the forum will let you post it ...
Hi everyone, yet another PID problem. I'm hoping I understand enough of the process I'm controlling that my request for help is reasonable. If a...
113
28,394
How can I test some PID code I have written for a SLC-500 in RSLogix500, without having an actual processor to test on. I have used Emulate500 to...
1,837
Hello, I have a PID block in my program controlling pump speed in order to get a correct Differential pressure. The way I have it set up is the...
1,265
I have a PID in a SLC 500 that does not function as it should. Have deleted it remade it and still have a problem also moved it up and down in the...
2,752
Hi all, Came across some examples today of PID instructions in an SLC 5/04 with the Setpoint (SMax) & Setpoint (SMin) both set to zero. In...
1,962
