hello friends.we have a problem about SLC remote addressing.
we have a 13 slot chasis, 505 cpu mounted on it. and another 7-slot one about 50 metres away.we want to establish a communication between them. for this, we purchased a 1747-SN (B series), and a 1747-ASB. we installed SN module to the last slot of the main chassis and the ASB module to the 1st slot of the remote chassis.
but we couldn't succeed to make them communicate each other.will you please help us.?
cables and resistors and groundings are OK.
1747-ASB configurations:
SW1: ON ON ON ON ON ON ON ON ( Logic Rack:0 Starting Group:0 )
SW2: ON ON 57.6K
ON Primary
ON allways ON
ON ON OFF ON 6 Groups
SW3: OFF dont hold last
ON AutoRestart
ON Restricted
ON not last chasis(because primary chasis cant be last one)
ON OFF 1-Slot addressing
ON Discrete
ON(OFF) first save(ON) then check(OFF)
1747-SN configurations:
SW1: ON ON 57.6 K
when we apply power LED statuses:
1747-SN: fault ledff comm led:flashing red
1747-ASB: fault ledff comm led:flashing green Display: Ade
what shall we do? do we have to write some codes into SLC? or are we making wrong DIP switch settings?
in the remote chasis we have one 16-input digital input module currently. if we can succed in this job we will install a new 16-output DO , and 8-channel Analog input module ..
we need your immediate helps....
thanks everybody
SW2: ON ON 57.6K
ON Primary
ON allways ON
ON AutoRestart
ON Restricted
ON Discrete
SW1: ON ON 57.6 K
thanks everybody
