slc100 422 to usb adapter
ken
yes it is from ind. concepts sc<gkdl-usb 2.0
I was wondering if it can be used on a coputer with no serial port and if so how to configure dosbox(74) for it.
thanks max
Yes it did. Rewatch it.
The video I posted is for the USB 1745-PCC. If you have the other one with just a serial port ( 9 pin) then I am
not sure if you can use it with a USB to serial adapter.
Contact Industrial Concepts.
http://www.ind-concepts.com/
Sorry for the delay, yes you can use our serial PCC's with USB adapter... ours or others but then need to be a good quality (like Keyspan) , we sell one that works great and has a lifetime replacement if it ever fails
The setup should be the same as ours just check your Device Manager to see what COM port the cable is
If you are having issues using DOS Box 0.74 then you will need to find the Configure Set up file... you should be able to find it under Start/Programs/DOSBox, 0.72 had the file in the folder and 74 hides the file
Hope this helps
I am looking for some old software or a programming module to connect to a SLC100/1500 (to upload/download program). Rockwell doesn't sell it...
1,676
Any one know what software would be needed to connect to SLC 100 and what OS i will need?
2,069
We have SLC Logistics Revision 2.09. Running Windows 7. We have a USB printer that I have successfully mapped to LPT1: We are able to print...
3,977
I'm using this with an expansion chassis to control my home brewery. I can't find any reference in the AB manuals to a real time clock. I would...
3,227
Hi. I´m trying to upgrade some machines in my plant. I want to change some SLC100 and SLC150 into SLC500 or Micrologix. Is there a way to convert...
1,889
