Ab slc100
dietejrwso
Jul 2013
Indiana
I'm using this with an expansion chassis to control my home brewery. I can't find any reference in the AB manuals to a real time clock. I would like to setup scheduled events based on the Y-M-D and time. Is this available in the data table or will I have to build a clock with timers?
I could be wrong but I don't think there is a real time clock for the slc100's ken would probably know better than me on this. If it isn't available, you could use timers to do your timing, might need tweeking every week or so.
You are correct, the SLC100 and 150 do not have a real time clock.
Consider using a micrologix 1100 which is not terribly expensive and the software is free. Plus you gain two analog inputs.
thanks for the replies.. I'll look into the Micrologix. In the short term it looks like it will be a timer driving some counters.
If you already own an SLC-100 and plan on having a computer hooked up to it I recommend looking at this:
http://literature.rockwellautomation.com/idc/groups/literature/documents/td/1745-td217_-en-p.pdf
For a home brewery you could look the Arduino route to save some $$$'s
Good Luck,
(8{)} :) .)
Well I dug the SLC and 2 expansion chassis out of the trash pile at work so it'll be hard to beat that price. Another question regarding the SLC-100, do they employ compare statements; >, < =, etc.
No.
Sorry, the SLC100 and 150 is a bottom dweller.
Search the forum and you'll find links to the manuals. Use the search link on the blue bar above the google search.
No.
you are going to need a pc with no more than XP on it to communicate to them, and the cables and software.
You wouldn't spend much more for a micro810 starter kit, it might do what you want for $190 and the programing software is free
here is a US link to it
http://www.plccenter.com/en-US/Buy/ALLEN BRADLEY/2080START810
Hi
You could use an external time clock like one for a heating system and just wire it to a input
Donnchadh
Windows 7 works great, the cable is 40.00 for a USB version and the software is free
I would also stay away from the 800 series and go with the 1000 or 1100 if I was going to change to another CPU, software is also free
I am looking for some old software or a programming module to connect to a SLC100/1500 (to upload/download program). Rockwell doesn't sell it...
1,676
Any one know what software would be needed to connect to SLC 100 and what OS i will need?
2,067
We have SLC Logistics Revision 2.09. Running Windows 7. We have a USB printer that I have successfully mapped to LPT1: We are able to print...
3,974
Can this adapter be used if computer has no serial port,if so what is used in dosbox config file.
4,746
Hi. I´m trying to upgrade some machines in my plant. I want to change some SLC100 and SLC150 into SLC500 or Micrologix. Is there a way to convert...
1,888
