SLC5/05 and PV1000
Rehu09
Nov 2017
USA
64
I have a SLC5/05 and PV1000 trying to connect both. I will be using Ethernet switch and straight through cables from pv to switch and another straight through cable from plc to switch. Will be assigning the ip address to plc and pv with same subnet mask 10.12.1.11 and 10.12.1.12. I will go and start rslink configure Ethernet driver and open Rslogix500 to download the program to SLC 5/05 and similarly I will use rslinx enterprise in ft view and download the .mer to the pv 1000.
Do I have to establish any communication in order to make hmi talk to plc. Or get the data from plc.
I have seen in few other posts people were trying to configure opc server. So please help me in that.
One more question about factory talk view.
While creating application. I have exported all the tags from my offline rss program and used the same tags in the screens. Will they going to work if I connect SLC 5/05 and HMI.
I will be downloading the same program in SLC 5/05 of which I exported csv files and used in ft view
Hi guys I was hoping to get some help with a recipe in pv 1000.Question that I have has to do with the "GOT TO SCREEN" in my case main menu button...
1,496
Dear all, Now,I've a PanelView 1000,and I want to connect it to SLC 5/05 through ETHERNET .After I finalized my tags and adjusted the connection...
3,663
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,574
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,286
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
650
