SLC5/05 IO TimeOut Reading
Thanks all for the input. We ended up replacing the back plane and in the process found a scorched resistor on the power supply, so replaced it as well. Not sure which or if both were an issue, but we have had no problems since out of the setup.
Not Sure What I Have Missed Or Need To Check Next, SLC5 Driver Request Timming Out On Node-2 [HMI] Listed Below Are The Findings/Results...
8,315
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,557
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,270
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
638
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
925
