I_Automation
Do they cycle power on the machine and does it only happen when it reboots?
This shop never cycles the power to their machines. They actually have signs on each one to not shut off the power except in an emergency. An EEPROM would help but the operators do not have access to the mezzanine the control panel is on - a mezzanine with a long set of stairs I have suggested more than once it would be nice to have an elevator for a guy with a bum leg.
This VRAM checksum fault occurs while the PLC is running, if the power is cycled then it wipes memory and goes to DEFAULT. Nicely when it does it keeps the COMM's settings of DF-1 38K baud.
I replaced the power supply just as a press repair company showed up to removed the 2 bull gears and get them replaced as they are missing a few teeth each. Fortunately THAT can't be blamed on the PLC, but will take this press down for a few weeks.
