SLC5/05 replaced with CompactLogix (iFix HMI re-programming?)
wfortuny
Jan 2011
Portland OR
19
We just replaced a SLC5/05 processor with a CompactLogix and are wondering if there is a way to create a "data file" in the compact logix that can hold the data in a similar format that the HMI would be able to access without having to re-map the tag connections between iFix and the PLC?
Thank you,
Bill
Main menu under Logic in RSLogix or iFix?
Thank you,
Bill
RSLogix 5000
An alternative would be to edit the tag database in iFix. I am a self taught novice with one version of iFix, so with that said...
You could edit the iFix data base to point at the Logix CPU, and to get there (on my systems) I run a program called DatabaseManager found in my iFix folder. It opens in a spreadsheet format and allows one to edit settings related to tags and comms blocks. There may be other tools involved, depending on which drivers you are using.
For me, it would be easier to leave the iFix stuff alone and "fake it out" by using the mapping feature in Logix5k to make the new Compactlogix "look like a SLC" to the iFix app.
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,563
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,278
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
640
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
930
Hi All, I have programmed some MSG instruction in SLC5/05 64k CPU series D FW 13 brand new cpu. 2 of the MSG instructions are direct IP to other...
984
