SLC500 file handling
sailor99
Jul 2005
Mississauga
I've just discovered this site. Fantastic.
Looking for help with file manipulation on a slc5/04.
I have a barcode scanner linked to a devicenet bus. The scanned 22 character ASCII result goes to M4:1.0 then copied to N14:0. The file length is 16. How do I convert this to a string and load the result into a FFL and what would be the max. len of the FFL.
Thanks.
I'm not terribly familiar with the FFL/FFU instructions but, I'm pretty sure they're designed to manipulate groups of 16-bit words like those in integer files, not strings. You'll probably have resort to indirect addressing to get where you're going.
Thanks for replying Doug. I was searching for an easier solution to a tedious programming issue. You are correct, FFL/FFU's can only work with integer files. I have to break the ASCII code down into single integer files and then reassmble them into 4 digit integers and load the integer files into parallel FFL,s. Then I'll do multiple
compares.
Ex If I Read from Integer file N7:0 N7:0 is an 8 point input card , input 0 and 2 are on , rest off When I look at : N7:0 -7 6 5 4 3 2 1 0 I...
748
How can I read individual binary bits from a SLC500 within FTH SE? With the Tag Browser I can get to the Binary Files and get each Integer from...
1,605
Cheers!, I am an experienced electron plumber, but completely new to PLCs. I am trying to exhume a SLC500-based (AB P/N 1747-L20A) Pallet...
25
4,924
Hi All I am Converting a Program from SLC500 to ControlLogix. I have exported the SLC files and ran them through the Project Migrator which...
1,345
Can someone tell me if it is possible to convert a file that was developed using the SLC Logistics software by ICOM to an (*.RSS) file that can be...
7,121
