SLC500 To CLX5000 Migration No Output .ACD file
ian.smith7
Aug 2002
UK
145
Hi All
I am Converting a Program from SLC500 to ControlLogix.
I have exported the SLC files and ran them through the Project Migrator which indicates everything is parsed OK but I get no .ACD file at the end.
Looking at the AB Knowledge base this is most commonly caused by Unacceptable characters in the .CSV produced by the RSLogix500 export.
I have edited the .CSV file (with excel) and cleaned up all the oddities.
There are only the following characters a-z, A-Z, 0-9, spaces and _(underscores) in all except column A which seems to contain all the I/O and register addresses.
Before the SLC Export I did not use the 'Delete Unused Memory' memory instruction
I am a bit stumped now, is there any thing else that I should check?
Cheers
Ian
Hi Guys
As usual 2 minutes after asking the question I worked it out.
The Migrator produces an .L5K Which then has to be imported but Logix designer is opened looking for an .ACD file in a different Directory to where the .L5K file is created.
Ian
Hi All I have just started a project to convert one of our machines from SLC500 to CLX5000. One of the first steps in the Rockwell guide was to...
1,985
I have searched the forums and looked pretty hard in the AB literature. I still am not 100% sure. Can you use a 1747-SCNR to produce/consume...
2,365
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
can the slc500 5/05 send a email and text over Ethernet ?
185
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
389
