Attempting to configure the following System.
Rack 1 - 10 Slot
SLC 5/04 [C]
SN Scanner
4 Channel Analog in
4 Channel Analog in
115VAC input (16)
115VAC output (16)
Empty
Empty
Empty
Empty
Rack 2 - 10 slot
RIO module
115VAC in
115VAC in
4 channel Analog in
4 channel analog in
Empty
Empty
Empty
Empty
Empty
Rack 3 - 7 slot plus 7 slot expansion
RIO module
2 in / 2 out analog module
4 channel analog in
DC out (16 channel sinking)
Empty
Empty
Empty
115VAC in (16)
115VAC out (16)
115VAC in (16)
115VAC out (16)
Empty
Empty
Empty
My question is what configuration do I need to get the block transfer working?
Switch settings on RIO's Config of SN Module and Ladder logic to read and write data.
Thank you, this is driving me nuts, I've been using AB PLC since before the slick500's came out but never used remote I/O.
Thank you.
Rack 1 - 10 Slot
SLC 5/04 [C]
SN Scanner
4 Channel Analog in
4 Channel Analog in
115VAC input (16)
115VAC output (16)
Empty
Empty
Empty
Empty
Rack 2 - 10 slot
RIO module
115VAC in
115VAC in
4 channel Analog in
4 channel analog in
Empty
Empty
Empty
Empty
Empty
RIO module
4 channel analog in
Empty
Empty
Empty
115VAC in (16)
115VAC out (16)
115VAC in (16)
115VAC out (16)
Empty
Empty
Empty
Thank you.
