SLC504 - DH+ address change
JCool
May 2006
North
Hi everyone!,
I have 6 504s and I'm putting them on a DH+ network, all nodes are currently set at 01. Do you know if its possible to change the node name online with doing a master reset on th plc?
any help would be great :)
Thanks in advance
I believe you can change the node address while running, never tried it.
Just go to the Channel 1 tab and change it. If you are connected via DH+, you will lose your connection, if connected serially, then no issues.
JCool said:
Hi everyone!,
Thanks in advance
I'm not sure, but I don't think you can change the address online. I think it has to be changed offline, then downloaded.
And I know for certain that you cannot change the node name online.
Worked like a treat, I changed the addresses through df1 via the channel menu. then connected all the dh+ cables. Thanks for all your replys :)
Just a suggestion - don't use node 1 on your network. If you ever have to add a processor or someone reloads a processor and doesn't correct the node number, then you would have duplicate node numbers and will cause errors and possibly fault the duplicate nodes.
1747-L541 processor. I was given a program to load into this PLC. When downloading via DF1 there's a message that the communication will be lost...
801
I am having an odd issue. After upgrading to FTView-10.01; I can no longer see tags on a microlgix1100 and a SLC5/04 that is going through a...
3,481
I'm looking for a cheap way to pull data from a controllogix system to a SLC504 so that I can use the DH+ connecting on the 504 which is connected...
2,324
Thanks for the replies following my initial post Re connecting via serial to a DH485 PV1000 We have now found a 1761-NET-AIC and a 1761-CBL-AS03...
1,713
