Slc504 Hsce
Mark Buskell
Sep 2003
Florida
892
Does anybody know of another module that I should look into instead of using the HSCE module. I am using an encoder to track line speed The encoder is optical type that has 1024 revolutions per turn and will be mounted on one of the machine rollers. I have always used the HSCE in the past for other applications but for this simplier app I was thinking that I might be able to use a cheaper module.
1747-L541 processor. I was given a program to load into this PLC. When downloading via DF1 there's a message that the communication will be lost...
805
I am having an odd issue. After upgrading to FTView-10.01; I can no longer see tags on a microlgix1100 and a SLC5/04 that is going through a...
3,489
I'm looking for a cheap way to pull data from a controllogix system to a SLC504 so that I can use the DH+ connecting on the 504 which is connected...
2,329
Thanks for the replies following my initial post Re connecting via serial to a DH485 PV1000 We have now found a 1761-NET-AIC and a 1761-CBL-AS03...
1,715
