elevmike
Rod, Thanks for the tip. I'll lookinto that also. But really I just wanted to have the orig for nastalgic reasons. Any real machining will be done on the new 14" x 42" convertable gap lathe, or the Bridgeport. (both have readouts).
elevmike said:My SB is older then yours, as there's no gearbox to the right of the drivescrew. I've just got a selection of gears and a chart to indicate which gears for what speeds or threads etc...
pstephens said:Mike,
That serial number indicates a mfg. date of late Jan/early Feb. 1936! I would be interested to see a picture of that lathe.
jstolaruk said:Paula (and other machine tool enthusiasts), I'm not sure if you are aware but there is an excellent forum called the "Practical Machinist"...
Rod said:Now where is Mike's tool post?
Rod said:It does not look like you have backlash adjustment for the feed thread gears - makes precision threading a problem.
