Slip Ring help need.
Ukrainian
Jan 2005
Pomona CA
19
Rotating device has a video camera to monitor right position of a traverse. Between camera and video monitor there is rotating wireless communication device. That guy fails often, and loose communication, until you stop the machine, and cycle power on/off to get reset it. I prefer direct coaxial cable run through slip ring. Before we spend time to experiment for quality transmitting at neighborhood of 40 Horse Power motor trough slip rings assembly, would someone one inform me if they have done such experiments and what was the results for quality picture on monitor (because of 40 HP frequency drive noise near slip rings assembly)
I heard that TURCK was coming out with some slip rings but don't know the specifics just yet.
Joe_WaZoo
Good Morning , We have a new packaging machine that have Slip Rings . We are using the Slip Rings for a rotary jaw assembly that has heaters...
5,120
One of our factories needs to start an old slip ring motor. I suggested that they use a common "resistor selector" system to start the motor then...
1,907
i don't know much about ac motor slip ring. i have small ac motor slip ring about 2 or 3 hp its possible to me to use VFD, any idea or wiring...
2,350
Anyone ever worked with ABB ASTAT or ABB MoCon drives? Thanks!
1,482
Hi, I have used Vfds for Squirrel cage induction motors. I am now required to use a Vfd with a Slip ring motor. My question is, what do I do to...
2,966
