small footprint drive
JeffKiper
Jun 2006
Indiana
2,464
I am going to hire 2 helpers. I am going to put a small training system together. Probably use the following hardware.
Micrologix 1100
RedLion G306A
Some relays, sensors etc.
I am looking for a small AC drive. I worked on a couple a few years ago that where not much larger than 2 or 3 packs of cigarettes stacked together. I would like modbus rtu onn the drive but it is not required.
120 vac single phase in would be nice
In the same, micro drive size as mendonsy's suggestion, AD's GS1 drives are the smallest I've used, but I'm not a fan of them. I've had a few die in the field, so I've stopped using them. Might be fine for a trainer (they're cheap enough). I guess if they die, it's good way to teach troubleshooting?... :ROFLMAO:
http://www.automationdirect.com/adc...l)/GS1_Drive_Units_(120_-z-_230_VAC)/GS1-10P2
When I need a small, inexpensive ($130 from Galco) drive that runs on 120V single-phase, I use the KBVF-13 chassis from KB Electronics. Same footprint as a DC drive chassis, just thicker. There is a Modbus option (~$50), but I've never tried it.
http://www.kbelectronics.com/Variable_Speed_AC_Drives_Inverters/AC_Drives_Chassis.htm
-Eric
Hi
I used some yawaskawa dives in the last while, great price, small size and some great comms cards that connect to Ab no problem and good manauls and good tech support this side of the pond anyway.
Donnchadh
-Eric
Not to hijack this thread, but:
Eric,
Do you know why the GS1's died? I like them for small projects, but I'll start looking elsewhere if they're flaky. I like and use the GS2 regularly with good results.
-rpoet
Jeff,
I've been buying small AB Powerflex drives on Ebay, 125 single input for less than 100 bucks. They are not "state of the art" but representative of what is out there.
I also found some 34 frame 3 phase motors. Now I have some small and relatively light trainers.
Good luck.
I'm looking for several line reactors rated under 5HP that are totally enclosed and can withstand a dusty environment without needing to be...
18
4,206
What I'm trying to do is essentially make a strobe light. I have a lighting machine what uses 110 for the output for the lights to create...
1,907
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
743
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
347
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,366
