Smith Meter S-Mass Pak Talk Software
enaq
Dec 2020
Batavia
Is anyone here familiar with the S-Mass flow meters from FMC/Smither Meter? I am looking to interface with the "MicroPak" transmitter module through a program called "PAKTALK" that would have been supplied on a "diskette." It should be a partially command-line utility.
Otherwise, I am open to any and all suggestions to communicate over RS-232 with this transmitter module. What are some things I could do over Putty, for example?
Thanks,
-Tim
Tim, did you ever find a solution for this? I have 4 of these to work on in the near future.
Thanks!
No, I never managed to communicate over RS232 since the only one I could interface with was installed in the filed and needed to immediately be re-wired into a new control panel.
I found out the pulse output was sinking and needed a pull-up resistor to +24V. Output 3 is the same way as the "zero status" signal, but isn't enough to drive a DC relay. It also needs a pull-up resistor appropriate to the PLC or controller input.
In my specific case the pre-programmed scalar on the smith meter was 113.64 pulses per pound.
Hello, Enyone know how to comunicate UCL MICROLOAD SMITH METER to a Plc Micrologix 1400?
2,006
I posted before that I was using a MicroLoad.net to talk to a Prosoft card in a controllogix processor. I have read a lot about the MicroLoad.net...
4,910
Sturggling a lot with long death times. Electrical heaters are damn slow :(. Any of you have PLC (Siemens) blocks/codes? I have seen a 300/400 FB...
41
15,151
Hi all, The problem is to control the dry mass with a delay time system. I know Smith Predictor method can do it but how to implement it on ladder...
3,777
Hello fellas, Can anybody tell me if they have done training in any of the following with FMC Technologies: Smith Meter® AccuLoad III Smith...
3,215
