softnet
Softnet user
Guest
S
hi folk,
what is different between Softnet-S7 and Softnet-DP?
I have install the Softnet-S7 to PC but still the PC can't recognize the licence!!
Regards
I had installed Citect and Cpu315-2dp, the softnet licence i installed
into the PC was Profibus-S7 but still the message pop up and request for
Order: 6gk1704 - 5CW60 - 3AA0( Is Profibus S7 licence )..
Why?
Regards
SoftNet-S7 is for comms from Step7 to PLC.
No, STEP7 has its own drivers. As an alternative STEP7 can connect 'inderectly' via a configured 'PC station' that uses the S7 protocol amongst others.
Softnet also provides an OPC server that allows other softwares like SCADA packages to connect.
'S7' means that it can connect to the CPU via master-to-master MPI or Profibus comms.
SoftNet-DP is for comms from say a SCADA program to PLC.
No, it is the same as above.
The main difference is that 'DP' means that the PC can be a Profibus master or or Profibus slave.
Softnet user,
you can connect to the 315-2DP cpu by either MPI or Profibus.
You probably need 'S7' and not 'DP' protocols.
Try to follow the guide I have put in the downloads section.
Use an OPC test client to verify the connection.
Hi, I'm not a siemens expert but we recently converted an old siemens PC into a virtual machine so we could run it on modern hardware. It was...
7,869
Hello everyone! We have a computer running on Windows XP 32 bits SP3 where Simatic Net Softnet IE 2008 Lean is installed, with C++ (VC6.0 and...
1,410
Hello all, My clients asked me to pass hmi Powermeter information from our substation monitoring system to his ERP system. Our equipment is...
4,519
Hello, I got 2 S7-200 communicating with each other and a computer with Simatic Softnet Lean 2006 communicating with both PLC. When...
1,445
hello guys could any one tell me what is SIMATIC NET IE SOFTNET-S7 LEAN and SIMATIC NET IE SOFTNET-S7 basis used for ?
5,173
