Source for liquid sensor
allscott
Jul 2004
1,332
I am looking for a sensor that activates when it gets wet. I need it to either switch a set of contacts or trigger a 24V sink PLC card. I know I've seen one of these before that looked like a hockey puck and seemed to work good but I can't remember who made it.
Does anyone know of a sensor like this that they could recommend? Google just can't seem to find what I am looking for.
Allscott,
This may not work for you. I have used a micro switch with a lever actuator and an asprin tablet to hold the lever up. when the tablet gets wet it softens and the lever moves down. It helps to bend the lever so only the very end is in contact with the tablet. The advantage of this setup is it can sense the very bottom of a cabinet or the floor. Thus the cabinet or room does not need to have a half an inch of water to trip the alarm.
The omron system consists of a controller (this can be used as a single probe system or two probe i.e. on/off on probe level or on when top level covered & off bottom level uncovered).
However these are no good on oil based liquids you would need a capacitive probe or a mowbrey type float switch.
the controller has a relay output with two inputs + ground it uses the resistance of the liquid to detect between the probe(s) & the ground connection.
Alaric said:
Instead of looking next door look in the backyard. 🍺
I tried the backyard, just never thought of searching for wet floor sensor. :)
Anyway thanks for the link, I think the waterbug will do exactly what I am looking for.
Milldrone I like your ingenuity. It might be interesting trying to write a SOP on what to do when the sensor "trips" though.
I would recommend Endress and Hausser brand of sensor. I`m using it in all my level controll in all types of liquid application.
Regards:(y)
Sherwin
I will recommend Endress and Hausser sensor. I`ll been using it in all of my liquid type application.
Regards:(y)
Sherwin
Sorry I`ll sent it twice
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
198
Hello Friends I have a installation with v16, v17, v18, v19, v20. When I tried to open a v20 file, the enable source protection was not enabled...
254
What is your perspective? Are you a Maintenance Tech? Systems Integrator? OEM Engineer? What are your thoughts on the topic of source...
24
1,184
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
763
We have a Rockwell 1734 IE8C 8 channel analog input card, but we don't know if this is sourcing or sinking. The user manual doesn't seem to have...
1,150
