speed control based on moisture
hounddog
Jun 2003
79
I also posted this in another forum, but realize that there are folks who use this forum that may not use that forum, so hopefullys someone may have tried something like this.
Have a question that I hope someone may have a good answer to. Have a machine that is a dryer that fabric is feeding through at speeds from 0 to about 70 yards per minute. We have been brainstorming about would it be possible to have the fabric as it exits the dryer run across some type of sensor that would measure the moisture in the sensor and also have some type of infrared temperature sensor to detect the temp of the fabric as it exits. Based on the moisture and the temp. determine how fast to run the fabric. For example, you enter a set point to run 40 yards per minute and maintain a moisture of 4%. and use the signals from the sensor to control a pid that would be used to tune the setpoint, plus or minus a percentage of the speed setpoint to maintain the 4% moisture. Does this sound something that would be possible, and if so, any suggestions, ideas would be greatly appreciated. Thanks
no, it is a fabric dryer, cloth feeds through the front of the dryer, which is about 70 feet long, then exits out the end and is stacked to be used in another process.
Hounddog
Your description in your first post will work fine.
I've worked on similar machines and that's how we
Did it too. We also did a dwell time control with pyrometers.
(Like the Mahlo system, but not as nice :)
It may take some time to tune though.
Keep us posted!
Thanks for info, have some meetings,(brainstorming) this week, would it be possible to maybe post a sample of anything that any of you may have tried in the past. I done quite a few projects where I tell a motor to run a set speed, then use a dancer analog sensor to trim that speed by a percentage, took a quite a bit of testing to determine what percentage range, but speeds where only around 20 ypm, this will be 0 to about 70 yards per minute,
When I worked in textiles, we had moisture monitor systems by Strandberg on all of our West Point slashers.
Here is their website.
http://www.strandberg.com/
Thanks, actually found them after doing a lot of searching on the net today. What was the cost? Also, did you use the sensor and feed it back into a plc, or did you use the meter with the sensor? Looks like a very good product, almost identical to what our managers wants to try and build, heck, looks like these guys have already done all the home work. Like the looks of it.
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
962
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
743
I have two drives that control two seperate pumps that need to control pressure for plant cleaning. The company wants one pump to be running and...
691
Hi, I've bought this PLC + HMI from Aliexpress, the one on the right that uses SSRs. and want to connect a 24V/0.2A DC fan to the output. My...
32
7,109
Hey everyone! I'm searching for an example demonstrating how to program in Studio 5000 speed control of a PowerFlex 525 drive via Ethernet. While...
657
