split a DINT to 4 bytes?
MrQ
Feb 2005
236
Hello,
I have just started programming RS Logix 5000 for Compact logix.
What is the proper way to split a DINT to 4 bytes?
Create a Dimension 0 = 4 SINT Data Type Tag array and then COP/MOV the DINT within starting with the SINT [0] array element;
reference the four SINT array elements individually.
MOV won't do it, you need to use COP (or CPS), and you need to specify the length as 4.
To fortunebrass
Purely commercial posts are not welcome.
But, if you sell a specific solution for a problem being discussed in a thread then a reference/link to that specific solution is generally allowed.
hey all, I am struggling with a problem here and out of ideas on how else to achieve the desired result. I have a monitor inside a machine with...
134
Hello everyone. I have an PLC L35 (fmw 16) with address 192.168.1.1 and too many connected ethernet devices (3 hmi, a lot of ethernet port, asi...
757
Basic question: I don't understand why Network 4 is split over two lines. I want it to appear like for Network 3, i.e. all on one line. Does...
751
Hello I have a project to record temperature from thermocouple and store it to memory card, the problem is my client didn't provide new...
2,964
Hello, I have following control task. I have to limit a current drawn from a source of power in a grid where I have following power consumptions...
1,980
