Split washers do not effectively work!!
Red also works great if you want to play a prank :eek: (not that I ever have)
Either a prank or security feature I used:
Weld a hex nut on a piece of threaded rod. Cut close to the un-welded side. Drill through with the correct size tap drill. Re-tap the nut and the remaining part of the weld.
Use it and it looks like the nut is welded on. Easily removed though.
Works great for 1/2" and larger, smaller sizes tend to push the weld out instead of cutting into them.
hey all, I am struggling with a problem here and out of ideas on how else to achieve the desired result. I have a monitor inside a machine with...
129
Hello everyone. I have an PLC L35 (fmw 16) with address 192.168.1.1 and too many connected ethernet devices (3 hmi, a lot of ethernet port, asi...
747
Basic question: I don't understand why Network 4 is split over two lines. I want it to appear like for Network 3, i.e. all on one line. Does...
750
Hello I have a project to record temperature from thermocouple and store it to memory card, the problem is my client didn't provide new...
2,952
Hello, I have following control task. I have to limit a current drawn from a source of power in a grid where I have following power consumptions...
1,968
