Ones_Zeros
Hello
I have a dual speed fan that has a low and high speed.
The PLC is an AB SLC 505
I have most of the start and stop logic
completed, but I’m having problems figuring out how to
get the fan to go from High to back to low speed at a certain temperature.
Here is what I have so far
1. At a certain ambient temperature based on a Setpoint
the fan will come on at low speed (LEQ) This allows to blow hot
air during cold temps. I have the low speed output looking
at another temp transmitter, once this temp is reached it
will unlatch the low speed output, start a 60 second timer to allow to stop the fan completely and then start the High speed output fan.
2. If the temperature is above the Setpoint in step#1
then the High speed output comes on first. No need for the low speed at a higher
Ambient temp.
3. Since this is the same fan and it has two speeds. It takes about 60 seconds for
the low speed output to stop and about 30 seconds for the high speed output
to stop.
4. Here is where I’m have trouble from High back to low. If the high speed
output is running and then the ambient temp drops back down to the Setpoint where I need to start the low speed output again.
How would I do this to where it would stop the high speed & allow a 30 second delay before starting the low speed output?
5. Where I have the low speed coming on at a certain ambient temp in step #1
I wasn’t sure how to accomplish the high back to low without affecting step#1
I really appreciate the help
Ambient temp.
to stop.
