The new module arrived today, and the symptoms were exactly the same. It was a little disappointing, and also a relief that I know for sure the module is ruled out as a possible cause.
So, asking around among the guys, I found out we use tinsel on a bag making machine and stock a 21" long piece in spare parts. So, I added that to the infeeding conveyor so that it touches the plastic belt and the cartons just as they enter the scale conveyor.
This did not appear to help. So I got my meter out again and began probing the cases, the conveyors, the drive rollers, etc...looking for potential between some of the moving parts and the frame. I found that the outfeed belt was generating 4 to 10 volts on its drive rollers. This is a short rubber coated belt that was once upon a time a gap creating belt, but it is really not even needed anymore (if we extend the next conveyor a bit). It has three static generating drums near the output of the scale conveyor, and they are all making juice. There are two rear idler rollers and a take-up roller.
So, I rigged up some short pieces of copper wire and bolted them to the bearing blocks and bent them around in such a way that they are discharging the voltage from these rollers. Sparks are evident here when I touched copper to spinning roller.
End result is that is has been 30 minutes so far with no errors. Tomorrow, after checking the alarm logs, I will try removing the tinsel from the infeed and see if it's just the static from the outfeed that has been kicking my a$$.
I am not calling this one solved just yet, but it is definitely progress...
