Beggar
I'm writing a Rate-of-Change routine that uses the WSR function within Step 7 to progressively fill a data block. I then use the two extrema to calculate the rate of change.
My problem is that early in the acquisition cycle, the upper words in the DB are 0, so I don't want to use them in my calculation. I'm using a counter to keep track of where in the DB is the first non-zero data point but I don't know how to grab the value.
Is there a means by which I can use an index (the value from my counter) to grab the value of a specific word within a data block (for example, word #4)?
Once the data block is full, it's not a problem for I just use the first and last words. For the first part of each cycle, though, I need to use only the first word and whichever is the highest populated word.
