step 7 micro win programming
Jul 2012
Singapore
51
hi friends
For one of my project i am using siemens PLC. cpu 224
I have 16 analog inputs. just have to monitor and give the alarm if the level exceeds 20%. 4-20mA current input to the analog slot channels.
can i use the S_ITR instruction for all these?
please advice.
thanks
chitra
For those like me who had never seen the S_ITR instruction it is part of a 'Scale' library that you can download from the Siemens website. What happened to the day when you did a I to DI, DI to Real and then wrote your own scale function!!
http://support.automation.siemens.c...csview&extranet=standard&viewreg=WW#A27196050
In answer to chitra:
The S_ITR instruction converts the Integer from the analog input to Real and then scales the Real to get an output. It won't give an alarm, you could use a compare instruction for that, unless Siemens have also given a 'alarm' function to download.
I'd write my own function to scale and detect limits and call it 16 times with different parameters.
Good day we have a very old software project that was downloaded to a S7-200 plc We have bought the Micro/win v4 software so that we can try...
22
5,394
Hello everybody' I am newer. I use position control wizard in tool to get some subroutines. but I don't know the input and output parametes...
1,700
Someone gave me an S7-200 this morning. Don't know what I'm going to do with it - maybe learn a little bit to broaden my horizons... maybe sell...
2,753
Hello all! I just started to "play" around with Siemens. I have installed SIMATIC Step 7 Micro/win v4.0+sp4 (v4.04) on a Vista machine. S7-200...
17
9,567
Good day to all~ I'm new to the world of plc and programming hope u guys could assists. thanx. I'm using STEP-Micro/WIN V4.0.8.06 with modbus...
2,298
