Step5 FB25
romaitor
Nov 2018
spain
Hello,
I'm trying to migrate an ald S5 PLC(S5-95U). In the code there is a call to a FB25. I don't know anything about this block and I need information of how it works. In the picture I see "P71200-S 5015-A-1" but if I read than document, the FB it talk about has more parameters than th FB you can see in the picture attached.
Hope someone help me.
Thanks.
These blocks are for floating point operations.
I cannot find a manual, but if you have STEP7 V5, then there are S5-to-S7 conversion blocks for which you can have help.
Open Standard library .. S5-S7 Conversion blocks, and finde the header name, i.e. GP_FPGP.
For this block the online help says:
Parameter Data Type Memory Type Description
Z_12 WORD I, Q, M, L, D, const. High word of integer
Z_11 WORD I, Q, M, L, D, const. Low word of integer
Z_22 WORD I, Q, M, L, D High word of floating point number
Z_21 WORD I, Q, M, L, D Low word of floating point number
Description of instruction:
The GP_FPGP instruction (FC61) converts a fixed number (integer) to a floating point number.
Hello, I have a one off job to modify some Siemens Step5 software at a local factory. The PLCs are S5-100U (CPU103). I have uploaded the PLC code...
4,297
Hello Everyone! I just became a member of this great site. I have a PLC program from an S5-100U PLC, and now I want to make a PDF report of all...
1,578
Good evening, everyone, someone can tell me what is the best configuration to print my program from Step 5
1,080
hi all, im trying to check EPROM of siemens PLC U115 CPU 943B , and as i found its required STEP5 software but the required OS is Win xp or older...
1,740
hi everyone i'm looking for your heelp please i have a probleme with converting this in rslogix5000 :L KHE400 :+F :LIR 0 :T MW240...
2,568
