stepper motors and e-stop
isiah_s
Sep 2016
NYC metro
45
I am concerned that a stepper motor will lock when its enable signal is removed. Leaving operator with crushed.
Suggestions?
I think that the intent is to not lock the rotor. Removing the current from a stepper will allow you to move it more or less freely.
It will? I have not played with steppers before. The issue is it could crush a person's hand and if that started happening, they hit e-stop I am worried the motor would lock leaving his hand being crushed. You are saying steppers dont lock when the drive stops applying power?
If you remove power, the motor will not be "locked". Now that may or may not allow you to manually move a device. There could still be mechanical reasons that would not allow you to physically move the crushing device. I would say that your main objective should be to make it as impossible as you can to have a person be able to get into a situation where they can be crushed in the first place. Light curtains, gate interlocks, two hand stattions, lazer scanners, etc, etc, etc, etc.
I am still gathering information but everyone is saying it wont move after it has no power. You could be right and everyone else is wrong but I would not want to depend on that. You are definitely right about safety circuits, the best way to solve this problem. My coworker suggested an emergency reverse in addition.
Thanks a lot.
Thanks a lot.
Is there a brake involved? Motion under emergency conditions is not advised. Proper safety circuits will detect the operator's hand before it reaches the pinch condition so that harmful energy can be removed. In this case, a light curtain or safety mat?
No physical braking. Drive is given a stop command. A light curtain is what I will use, still reviewing the drawings now, also a safety circuit on the electrical and maintenance panels.
Is the stepper motor using a gear reducer?? Gear reductions will often prevent you from turning the output shaft even when power is not applied because of the high ratios involved.
No offence, but there seems to be a high degree of guessing and hoping.
If there is a risk someone can get their hand crushed, then you need to consult with someone who is experienced in carrying out risk assessments and designing safety functions.
It doesn't sound like you are at that level.
"If there is a risk someone can get their hand crushed, then you need to consult with someone who is experienced in carrying out risk assessments and designing safety functions."
+1 for machine safety risk assessment
Hazard reduction and emergency stop are two different aspects of machine design.
+2 for machine safety risk assessment.
If you're looking at a way to handle the situation where someone has already got their hand crushed in the machine, you're doing it wrong. Back it up a couple of dozen steps and find a way to prevent that from ever, ever being able to happen.
If there is no current at the stepper motor it will not have holding torque. The rotor will "stick" to one of the poles when unpowered but it is only a small torque relative to the operating torque.
The idea of course is to prevent them from being able to get their hand stuck in the first place.
Nope, they don't. How do I know this? I've got a Rostock 3D printer (which is a delta style printer) here at home. With the power off, I can move it at will.
As a side note, steppers make dandy generators, the display on the Rambo controller on the Rostock will light up as I raise and lower it by hand. Since it is generating, and supplying power to the Rambo board (the 3D printer's controller), cutting it loose entirely from a load would make it even easier to turn.
Thought I'd post this to help other's out :) Any further questions, don't hesitate to ask. Credit to Keithkyll for his advice!, Using 24v power...
2,042
Hello everyone, I have a project, use the ML1400(1766-L32BXB) control the two stepper motors(X axis and Y axis). i know the stepper motor no...
1,766
Has anyone ever done a stepper motor application using one of the new AB Micro PLC's? I'm curious what components you used on the stepper motor...
1,578
Hi I have 5 stepper motors with drivers(each can support pulse up to 300kHz) and I want to control them with PLC. Also need to control ramp...
3,513
I am quite new to PLC and have to build a solar tracking system. I have to move my stepper motor by 15 degrees every hour . That means 24 steps...
2,581
