storage card, Siemens MP370
ason
Oct 2005
Home
317
Hey i want to make a trend on a
Siemens MP370 15 TOUCH 6AV6545-0DB10-0AX0
And need a storage card
MP370 have USB-PC-card and CF-card,
i wonder if i can use a regular USB-stick or do i need to buy from siemens.
and if so, what is recommended, i need 128MB
We used to buy the CF cards from Siemens. Now we just get an aftermarket (SanDisk) CF card. These can be found at almost any electronics/camera store.
For MP370 you can use any CF card up to 512 MByte.
MP370 not support USB stick.
http://support.automation.siemens.com/WW/view/en/21847868
Windows CE 3.0 (MP370):
  • Memory cards with capacities of up to 512 MB.
  • USB sticks cannot be used.
Windows CE 5.0 (MP377):
  • Memory cards with capacities of up to 2 GB.
  • USB sticks can be used.
    No difference between USB connections. There is no guarantee that "Storage Card USB" or "Storage Card USB2" will be assigned to a stick.
Siemens resell SanDisk CF card with 6AV** label :)
Yes, the "Siemens" card really is just a SanDisk card with a Siemens P/N. Problem is, it's not easy finding 512MB cards anymore. It may be easier to buy it from Siemens (about $70)than spend the time finding it retail.
That said, on TP270s I *have* used larger than 512MB cards, I've used 1 MB and 2 MB cards. You get an error message when it goes into runtime, and it's "unsupported" by the hotline, but it does seem to work and seems to write data just fine.
I just did one of these, literally yesterday. It's true you'll get that error message and it will ask if you want to correct the size error. If you do, it will make the database stop working. I just erased everthing on the card though, and the HMI re-created the database just fine. Also, if you have trouble getting the logging to work, remember that the CF-card slot is seen by the HMI as "StorageCard2".
Cheers!
Maybe, maybe not.
Sandisk is the worlds largest flash card manufacturer, and they make many different versions, including industrial grade ones.
Is there a type no somewhere on the Sandisk card ?
The "I" in "SDCFIR-XXX-388" is for "Industrial".
So maybe there is difference between siemens and regular sandisk card,
I did not look what was under the siemens label,
if i get a chance i will take a look..
Hi, I am setting up a technical manual display page on a PANELVIEW PLUS 1250 HMI, and the page references .pdf files held on an SD card on the...
1,661
Hello Im working with a PV+1000, the panel got some issues (dont know exactly what), but the firmware got corrupted, and had to be upgraded and...
1,357
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
279
I'm working on an application and have hit a bit of a snag. I need to find an industrial touchscreen display that can: - Tolerate down to -40C...
760
I noticed that ME Terminal Info gives you lots of good info about the panelview except one VERY important one, that is how much available flash...
576
