Studio 5000 Download to PLC Failure
BlueAltezza
Nov 2012
Cleveland, OH
243
I haven't seen this error before and can't find anything in the help or knowledgebase.
I uploaded from a customer PLC (L24ER version 30.011) to get the latest info, made my changes offline, then went to download back to the PLC and got the following error:
"Failed to download over port specified by communication path. Cannot disable active communication port. Either select a different communication path or ensure that all active ports remain enabled"
Bottom has Error 457-80044478... which I couldn't find any information on.
I tried clearing and resetting the comms path with no luck. I find it odd that I can connect, save, upload, edit, etc but just can't download. I ended up just making all of my changes online instead so I could get my job done, but for future knowledge I'm wondering why that error appeared.
This machine was originally created in version 20. The customer has upgraded it to version 30.011 since then. Not sure if that would do anything wanted to note it.
My gut tells me it's Win10 related as I've been trying to use it as much as possible to see what works and what doesn't. I have a Win7 partition on my computer as my backup plan so I'm going to download the gigs of 30.011 joy later, install on 7, and try that tomorrow.
Any other suggestions or possible causes?
Download Failure
I recently had the exact same error. I just updated the firmware on an L33ER to v30. I have been using win10 OS for quite a while also. The PLC went from V20 which I was doing downloads on during development every morning to V30 which I now cannot "download to" through Ethernet. The only way I have found to actually download is through the USB port on the PLC. I talked to one of my local Rockwell guys and he sent me here and suggested I utilize my tech connect agreement and call Rockwell. I was hoping to reply here to see what you may have done to resolve this problem?o_O
Hi, I'm trying to add ethernet modules to one of our plcs, but I get about 15 errors that say "Invalid Signature. Reseal instruction to resolve."...
322
Morning Everyone, Was browsing the Rockwell download page this morning looking for the multiple version download and noticed an option I hadn't...
5,061
First post here. Software: Logix Designer 31.02.00 Professional (running as admin) PLC firmware: 31.011 (required by customer) Actual PLC...
2,685
I am a big fan of developing in Logix Emulate when I don't have access to a live PLC. That said I am running into an issue with not being able to...
1,539
Hello, I'm trying to look up a way to tell if the PLC has had any edits changes or download via a bit or GSV... My hope is to display a date and...
1,388
